I have a 1972 351C 4V and need a distributor drive gear. Is there another engine that uses the same gear so i can just go to the junk yard and get one? The cheapest gear i found so far is 50 bucks, and i can get a whole distributor for 20 at a junk yard.
Please excuse the caps, this info is out of some old files of mine:
CAST IRON DISTRIBUTOR GEARS ARE USED WITH CAST IRON CAMS AND ARE EITHER:
ORANGE 1.249 OD/ 0.467 ID FOR 289/302 W/ POINTS OR DURASPARK, M12390A
BLUE 1.249/0.531 FOR 302 W/ EFI OR 351W, M12390D
GREEN 1.421/0.531 FOR 351C/M,400,429,460, M12390G
STEEL DISTRIBUTOR GEARS ARE USED WITH STEEL CAMS ONLY AND ARE EITHER:
PLAIN 1.249/0.467 FOR 302 W/ STEEL BILLET OR PRODUC ROLLER CAM, M12390B
YELLOW 1.249/0.467 FOR 302/351W W/ HYD ROLLER CAM AND EFI, M12390F
BRONZE DIST GEARS CAN BE USED FOR CAST OR STEEL CAMS AND ARE EITHER:
BRONZE 1.249/0.467 FOR 289/302 W/ POINT OR DURASPARK, M12390C
BRONZE W/BLUE STRIPE 1.249/0.531 302 W/ EFI OR 351W, M12390E
BRONZE W/GREEN STRIPE 1.421/0.531 FOR 351C/M,400,429,460, M12390H
