Started engine, tried to drive, shift indicator showed the proper gear, nothing happened, nothing on all the forward gears, nothing in reverse. 4 wheels drive also nothing.
Scanner showed no output on torque converter. Anybody had this happen? What could be wrong?
1st thing I'd do is see if you can see the actually linkage on the transmission and have somebody move it through the gears while you're watching it. Obviously with the engine off, parking brake set etc etc.
Maybe the gear indicator reads from the shifter and not the trans and it's not actually shifting the trans. If it is shifting on the transmission I'd get it to the dealer.
