Sponsored by: Real Truck
Trans wont shift into first gear
Old Sep 14, 2011 | 04:05 PM
79 bronc's Avatar
79 bronc
2001 F350 C.C. 7.3 Dualy 4x4
I re-test drove yesterday. Reverse is fine, wouldn't shift into 1st to go forward. Then wanted to slip out. I made it down the driveway and parked it. Milage is 150, 000+, good fuild level and no leaks.
From what i read I'm guessing its the Diode. It probably need the sprage gear conversion. Does the diode apply to first gear problems as well as the 2-3 gear issues i've read.
What do you know about the Ford HD4r100 trans?
Old Sep 14, 2011 | 06:53 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The mechanical diode causes problems with the 1-2 shift. It doesn't affect first gear operation, nor does it affect the 2-3 shift.
Will it go forward with the shifter in 1 or 2?
Old Sep 15, 2011 | 11:09 AM
79 bronc's Avatar
79 bronc
No, it still wont roll forward, RPM's go up. I'' gently rev the motor a couple of times then the transmission will engage into 1st. Then it seems like it slips out of gear then. I barely made it 50 feet to park the truck.
How do you know if the torque converter has gone bad ( wont engage) vs. the transmission gears not engaging?
Old Sep 15, 2011 | 07:44 PM
Mark Kovalsky
If it is the torque converter it won't move in reverse, either. Your forward clutch is probably bad. There is nothing electronic that can do this, it has a mechanical failure.
Old Sep 16, 2011 | 08:21 AM
79 bronc's Avatar
79 bronc
That what i needed to know. After getting the trans done, should the TC be replaced as well. Is it recommended that these two componets get replace together, just to be safe?
Thanks Mark.
Old Sep 16, 2011 | 03:21 PM
Mark Kovalsky
Yes, replace the torque converter when the trans is rebuilt.
Old Sep 18, 2011 | 10:56 AM
79 bronc's Avatar
79 bronc
thanks mark,
makes sense to me.
Hammer&Nails
Sep 19, 2018 09:13 PM
DAVE67FD
Jan 10, 2018 08:13 AM
891/2ton
Jun 19, 2006 09:16 PM
theguide
Bronco II
Sep 6, 2004 04:39 AM
