Rubbing Drums
Old Aug 6, 2016 | 04:50 PM
john jamieson's Avatar
john jamieson
Rubbing Drums
I just got through replacing rear bearings and seals on my '66 F100. I also rebuilt the brakes and replaced the drums. The drums rub on the backing plate.
I've relieved some of the high spots on the backing plate but also have some rubbing in the groove in the backing plate. It is not all the way around. The first drums I got were Break Best Select. I just got some Centric and they also rub but not as bad.
Anyone else ever have this kind of problem?
Thanks.
john
Old Aug 6, 2016 | 09:31 PM
'65Ford's Avatar
'65Ford
Never saw what you're describing but had a new drum with the center hole and bolt holes off center. Maybe that's causing your problem?
Old Aug 6, 2016 | 09:43 PM
Tedster9's Avatar
Tedster9
Probably imported, a lot of that stuff is a little vague when it comes to dimensions. The wheel cylinders often don't fit without a little time at the grinder. Cast US drums aren't that much more expensive?
Old Aug 7, 2016 | 05:35 AM
'65Ford's Avatar
'65Ford
The ****-eyed drum I got was for a 1996Ranger from NAPA. I always ask them for the "good stuff". Any idea where I can get US stuff?
Old Aug 7, 2016 | 09:06 AM
Tedster9's Avatar
Tedster9
Unfortunately no, with a Ford part # maybe hunt around for NOS from some of the obsolete part vendors or that auction site.
Old Aug 7, 2016 | 10:10 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C4TZ-1126-A .. Rear Brake Drum / Obsolete
1964/67 F100 2WD/4WD
MILLER OBSOLETE PARTS in Binghamton NY has 1 = 607-722-5371.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 1 = 800-476-9653.
HAVEN FORD in Haven KS has 2 = 620-465-2252.
AITKEN MOTOR CO. in Aitken MN has 2 = 218-927-2169.
KOEHN MOTORS in Wellington KS has 2 = 620-326-5915.
GREEN SALES CO. in Cincinnati OH has 6 = 800-543-4959.
Old Aug 7, 2016 | 11:26 AM
Tedster9's Avatar
Tedster9
Thank you Bill
Old Aug 7, 2016 | 09:51 PM
'65Ford's Avatar
'65Ford
Okee doke. Thank you, Tedster9.
Old Aug 7, 2016 | 11:03 PM
john jamieson
Update. I took off the Centric drums and looked for any rubbing areas and really didn't see any. Put them and the wheels back on and did a spin test and then a drive test and no rubbing. The Centric do look like a higher quality drum as opposed to the others.
mauicruza
Nov 11, 2008 06:57 AM
heel&sole
Aug 12, 2005 08:41 AM
mymerc
May 13, 2005 01:19 PM
donsboy
Mar 22, 2001 01:45 PM
