'96 7.3 PS turbo wont spool
I picked up a 1996 F250 ECSB 4X4 the other night. I haven't had a chance to dig into it much at all but here are some things I've noticed.
*runs cold all the time
*no black smoke when charging a hill and pulling a trailer
*turbo won't spool
Tonight I am going to replace the fuel filter, flush the cooling system and throw in a new thermostat. I just thought I would see if anyone had any input on the turbo issue and the lack of particulate. I'm not trying to "roll coal" but with what little experience I have in a diesel, it seems abnormal and underpowered. Thanks for any input!
*turbo won't spool
these do run cold and don't usually make lots of black smoke
Do you have a tire pressure gauge to check fuel pressure? must be over 40 psi at idle and WOT
Filters, oil and other PM stuff should be done since you don't know when it was done last.
Do you have a boost gauge?
Might want to get one and an EGT gauge when towing
Exhaust leaks? any will cause boost to drop
Turbo to engine leaks can happen and that will make for low boost
Have a scanner yet?
You can get a GT scanner and app for under 15 dollars that will tell a lot about what is going on in the engine.
Have a scanner yet?
With a good t-stat these trucks should get up to the R. Mine gets up to the M with the 203*
Fuel psi should be min. of 63psi at idle.
Have a scanner yet?
Have a scanner yet?
Thanks for the replies
Milwaukee1979F150
32
01-25-2012 11:56 AM
Fordson1
02-11-2007 08:59 PM
