bad vacuum modulator?
Old Aug 6, 2016 | 02:34 PM
86.9's Avatar
86.9
When you pull the vacuum line off the modulator and tranny fluid comes out it means the modulator is bad doesn't it? The transmission is a C6 behind a 6.9 diesel. I was going to adjust it to see if I could get it to shift at a higher rpm and found this when I pulled the line.
Old Aug 7, 2016 | 11:25 AM
hiball3985's Avatar
hiball3985
Should be dry. If fluid is there it is coming past a leaking diaphragm in the modulator. Replace it.
Old Aug 7, 2016 | 06:35 PM
86.9's Avatar
86.9
Thanks. I knew it was bad and have one coming. I guess I just wanted affirmation
Thinlizzy13
Aug 25, 2015 03:45 PM
HillBillyBuddha
Mar 13, 2014 04:25 PM
82f100460
32
Mar 3, 2012 10:59 PM
IDIDieselJohn
Sep 10, 2011 09:22 AM
Agemenon
66
Jul 9, 2007 11:09 PM
