I just fixed this same problem GPR was culprit I by passed the smaller wires going to it realay #2 stopped clicking had a WTS light and truck started right up. Unplug those two wires and connect them together and try it.
Thanks, will try that this morning. I do have a new GPR coming so hopefully this it it.
I assume the GPR isn't providing a proper ground if this is the issue? I then have to assume that the code reader is somehow bypassing this when it is plugged it?
Why connect them together? I just pulled them off the GPR and taped them up individually.
Connecting the two small wires creates a direct short from the fuse #22 circuit to ground, at least during the time the PCM would be energizing the GPR.
Originally Posted by z31freakify
It won't start if the circuit is not complete, you won't get a WTS light either.
Mine have been taped individually apart for a thousand miles now. When I was on the way to RRE and had problems (you might have read it) Bill suggested I tape them apart. They will stay that way until mid Oct when I get back to AZ for the winter when at that time I will put on a new GPR and test the PCM and IDM that I replaced to try and figure out what happened. The problems started with a CPS code and ended with a CPS. My GPR MIGHT have shorted out sending a ground thru the PCM and IDM, IDK and probably will never know.
