Front wheel and tire position
Old Aug 5, 2016 | 08:05 AM
78F350CobraJet's Avatar
78F350CobraJet
I am having an issue. I have a big lifted '78 with front and rear Dana 60's. I have new 38x15.5R20 tires and wheels, but something doesn't add up. This is build number 4 for me and my old man. We will call the current build the white truck and the previous build the black one. We have another '78 with roughly a 7-8" lift, the black one, and I test fitted these big tires on it and they didn't rub at all. The weird thing is, the white one is at minimum 1" higher at all fenders. The only thing I do notice is that where the tires sit in the fender well, the front two on the white one sit about an inch or two inches toward the front, off center. I don't know why though. Could it be the front leafs are sagging too much? Just looking for some help, thanks.
Old Aug 5, 2016 | 01:23 PM
weldman's Avatar
weldman
double post
Old Aug 5, 2016 | 01:24 PM
weldman's Avatar
weldman
I'm assuming the front axle is an implant? Axle spring pads different from the factory axle? I don't think sag would be it, the axles would still travel up and down on the same plane.
Old Aug 5, 2016 | 01:30 PM
PA74F250's Avatar
PA74F250
Are they newer Superduty springs?
Old Aug 5, 2016 | 08:40 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
X2 oh who did you get the lift from and was it 73-79 specific or a set of SD lift springs transplanted?
Did you add longer rear shackles? They look stock though....
Does the black truck have the same lift and front axle set up as the white one?
Old Aug 6, 2016 | 08:43 AM
good to doo's Avatar
good to doo
I would say the springs are not the right ones, the spring center bolt is off.
Old Aug 6, 2016 | 08:44 AM
F-250 WARHORSE's Avatar
F-250 WARHORSE
Sounds like the front leafs might installed backwards!!
aussiecowboy
Jan 16, 2013 09:17 AM
Campbell 56
Feb 27, 2008 09:33 AM
robert collison
Offroad & 4x4
Jan 7, 2006 01:08 AM
fordtruck4x4
Offroad & 4x4
13
Oct 8, 2004 01:24 AM
