Sponsored by: Real Truck
gauge wiring disaster
Old Aug 4, 2016 | 11:50 PM
14SD4Jeffro's Avatar
14SD4Jeffro
not yet, but if I attempt to do it myself without suggestions, it WILL be
would like to save the $200 I was quoted from the dealership for this install by doing it myself.
hopefully a simple install, but when it comes to electrical connections & a new truck, I'm just not going to jump in without knowing for sure what I'm doing..wrong wire & the gauge is the least of my troubles.....
bought a simple autometer voltage gauge & single bracket, located a location for the bracket & am awaiting the gauge bracket to hold the gauge in the mounting bracket (thought the gauge would come with it..that's what I get for thinking)
looking at the wiring diagram:
black to "good engine ground" THIS ***** I've got!
white to +12v Dash: any suggesions as to an easy to locate & work with source for this connection?
Red to +12v ignition: again, not looking to accidentally hook into a canbus circuit or some other computer network wire, just a good, accessible way to connect this wire.
I've heard that some of the wiring is extremely sensitive to even the slightest voltage fluctuation & the last thing I want to do is pay a fortune to have my errors corrected
Old Aug 5, 2016 | 04:10 AM
Chuck's First Ford's Avatar
Chuck's First Ford
white and red to 12 volt power port,,, aka cigarette lighter plug
Old Aug 5, 2016 | 06:44 AM
speakerfritz's Avatar
speakerfritz
d
d
I would run the wire thru the firewall grommet and use a fuse position that is always hot for this. you can get a fuse jumper at any parts store that will let you extend the fuse position and provide you a connection wire.
d
I would run the wire thru the firewall grommet and use a fuse position that is hot with key on for this. you can get a fuse jumper at any parts store that will let you extend the fuse position and provide you a connection wire.
use a multi meter to test for hot always, hot only with key on.
another good thing about this is you can disconnect it pretty easy if you have to go into service for electrical related warranty work. you know the deal, its your fualt your truck computer burns out becuased you changed your plastic air valve covers to metal ones...etc
alchemist1
Aug 15, 2014 08:51 PM
ManfredVonRichtofen
1978 - 1996 Big Bronco
Jun 10, 2013 01:49 PM
Ian123
May 27, 2011 07:37 PM
powerstroke1869
47
Feb 6, 2008 07:56 AM
airharley
Electrical Systems/Wiring
Feb 5, 2002 01:43 PM
