'93 Quarter Glass Replacement
I need to replace the quarter glass on the driver's side of my '93 F150. Does anyone know how to remove the window? I would like to know what I am dealing with before I just start taking it apart. If I buy it new it will cost $420 so I want to save some cash and get one at a junkyard.
Roll window down
Remove the door panel
take out weather strip that runs on wing window channel of the main window
remove 2 phillips screws on A piller of door
remove 11mm bolt that holds from window channel to the door
tilt the whole wing window, channel assembly back, and slide out of the door
Remove interior trim that surrounds window
Unbolt the glass
Push outward. You have to push hard to break the seal of the dumb dumb
reidhunt
1983 - 2012 Ranger & B-Series
Oct 19, 2007 07:24 PM
