Stiff steering
Old Aug 3, 2016 | 09:07 AM
green_95's Avatar
green_95
Stiff steering
My 97 f250 has hard steerin when your just idling along through parking lots. It pretty much doesn't have any power steering at idle speed when your trying to park in parking lots. Makes it pretty much impossible to park in close quarters. Power steering pump is full of fluid and is not whining or leaking. It has new front axle u joints.
Old Aug 3, 2016 | 09:11 AM
knottyrope's Avatar
knottyrope
mine is same way but never tried to up the idle to see any difference
Old Aug 3, 2016 | 02:15 PM
z31freakify's Avatar
z31freakify
Collapsed high pressure line can cause this, also a bad power steering pump.
Old Aug 5, 2016 | 01:18 AM
CC-F250's Avatar
CC-F250
Do you have tilt steering? Also is there any noise while turning your steering wheel? If the answer to both is yes, you may have worn bearings in your in the upper steering shaft - it's a common problem with our vintage. I just had mine replaced - bearings and upper steering shaft. The broken bearings destroyed the shaft. I heard the noise and ignorantly ignored it until it started affecting the steering effort. Also, if you have tilt steering, don't use the wheel as a grab handle to pull you in the cab. That's what most attribute the wear to.
thunderbird1986
2004 - 2008 F150
Dec 24, 2018 10:10 PM
Mustangfreak
May 13, 2009 08:01 AM
suzanne9273
May 1, 2009 09:34 AM
RealEstateGuy1000
Jul 29, 2008 07:46 PM
xuare
Sep 30, 2002 09:29 PM
