Commuting in a slick
Old Aug 4, 2016 | 10:44 PM
'65Ford's Avatar
'65Ford
I favor a shroud so long as you space your fan into the "sweet" spot. I found one from NPD that fits my '65. I believe the one I got was for a '67. The situation where they help is when you've went from high way speed to stop and go. Also helps to have over drive pulleys...in other words have a crank pulley about an inch bigger in diameter than the pump pulley.
2x on verifying your ignition timing.
Old Aug 4, 2016 | 11:30 PM
PROSTOCK's Avatar
PROSTOCK
I used mine for several years to commute to work when I lived in Austin. Trust me, it gets plenty hot and there's more stop and go than I cared for. I still run the original radiator, no shroud, and no issues ever.
Old Aug 12, 2016 | 07:18 AM
dman2008's Avatar
dman2008
I run 2000 Ford Contour electric fans on my 460 and have an aluminum rad and it never goes past 180*. I love my electric fans they work great, even when your sitting they keep the air moving and the engine right where it needs to be.
D
Schuyles
13
Jan 19, 2022 03:31 PM
HarryPutnam
29
May 16, 2011 12:31 PM
oldtruck56721
Flathead V8 & Flathead 6
20
May 29, 2010 03:55 PM
gtex
Aug 1, 2003 11:56 AM
burlii
37
Aug 26, 2002 01:05 PM
