Why can't I reset my fuel filter life? (UDATE from dealer)
Changed fuel filters today for the first time. 8800 miles. All went well, but when I use info screen to get to "fuel filter" to reset like I saw on youtube, it's not there. Only coolant. Should I care? Is it supposed to be there? Does the truck have to tell me it's time to change them before it shows up? Thanks.
Yes, I do have the LCD screen. I scrolled through like they did on the video, "settings... vehicle" etc but when I come to the screen that supposed to have coolant, and fuel filter, there is only coolant.
Thanks. Don't see it there either. I will confess, I haven't looked in the owners manual yet. Going in to the dealer Monday for oil change, I'll ask them about it then.
Edit: Is this the screen you have already tried?
https://www.ford-trucks.com/forums/1...l#post16437415
Wish I could help more, but I'm not in a position right now to go to the truck and scroll through the menu. I do recall having to look for it though.
Ok, at dealership now for oil change and the SA said that the fuel filter reset will not show up Unless the truck thinks it's time for new ones, or the fuel system gets plugged.
On separate subject; I asked about them installing the "ghost screen" with DPF soot %. They said no problem, $105 I'll probably do it, but sheesh, it only takes a minute or two. Guess I shoulda went back and tried to get the tech to just do it.
Just curious what have they changed on the regen cycle?
Is it worth getting done?
Do they charge you to update the PCM to the latest software?
Thanks in advance!
texasdynarider
12-13-2011 11:55 PM
wiccantoy
05-30-2010 10:39 PM
GotLift
06-02-2006 06:01 PM
