302 stump puller
Old Jan 14, 2002 | 07:33 PM
ethomas's Avatar
ethomas
302 stump puller
I have a 89' F-150 4x4 302 5 speed i want to build it for pulling anyone have any ideas and for under 2k$??
Old Jan 14, 2002 | 07:36 PM
orange peel's Avatar
orange peel
302 stump puller
im not sure how much it costs but putting lower gears in it would help out a lot, i would say around 4.11:1 - 4.56:1, im guessing not quite sure.
Old Jan 14, 2002 | 07:39 PM
DeGideo's Avatar
DeGideo
302 stump puller
Get an RV-type camshaft,a set of headers,and upgrade the rest of your 302's exhaust system.You might even try to have the stock heads mildly ported.This should help your 302 become a stump-puller for under $2,000.Good luck.
Old Jan 14, 2002 | 07:45 PM
ethomas's Avatar
ethomas
302 stump puller
Got flowmasters on it now was thinking about headers too the motor is get wore its got 145k on it and they r hard ones so going to do a rebuild.
Old Jan 14, 2002 | 11:00 PM
brett_d's Avatar
brett_d
302 stump puller
You can't port the heads or put a cam in it unless you convert it to mass air. Of course you can do it but it won't gain any hp..
best thing for a 302 for pulling is gears. The next thing I would do is exhaust!
Old Jan 15, 2002 | 01:00 PM
DeGideo's Avatar
DeGideo
302 stump puller
I agree with adding lower gears,but you don't necessarily need to switch to mass air(vs. speed density electronics) if you choose a mild RV-type camshaft that is "computer-compatible." Many aftermarket cam companies offer EFI302 cams that work well with speed density systems.My EFI302 Bronco has an aftermarket cam in it,and it did add horsepower&torque to it.Keeping the lobe separation between 113-115 degrees&shouldn't be a problem.For an all-out horsepower EFI302 truck engine,I'd add mass air,but for stump-pulling duties you'll need torque more than horsepower.A mass air conversion kit would push the upgrades in excess of that $2,000 figure.All said,exhaust &gearing upgrades are probably the first step to take.
Old Jan 15, 2002 | 07:34 PM
Pastmaster's Avatar
Pastmaster
302 stump puller
4drf350
1966 - 1977 Early Broncos
Jun 2, 2015 09:33 AM
Undertheoaks
Mar 30, 2014 09:48 PM
fordguy76
Apr 16, 2007 05:26 AM
JPontius
May 10, 2005 07:52 PM
trucksforever
2004 - 2008 F150
Jan 20, 2004 03:25 PM
