E4OD Issues
Old Aug 11, 2016 | 08:10 AM
  #31
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Originally Posted by 0500757Arf
Well looks like it's getting a upgraded converter sooner then expected then....but couldn't the opposite happen as well then? Like if something in the trans is broke that I can't see with all I took off right now and I put a new converter in, couldn't those broken pieces be flushed through the new converter and ruin it?
Yes it could.
Old Aug 11, 2016 | 08:27 AM
  #32
0500757Arf's Avatar
0500757Arf
Hahaha yeah a "drop test" It was actually a wood floor believe it or not so not AS hard as a concrete drop but still a drop none the less
Old Aug 11, 2016 | 08:29 AM
  #33
0500757Arf's Avatar
0500757Arf
Originally Posted by Mark Kovalsky
Yes it could.
If I could borrow a torque converter from a 4x4 E4OD out of a 96 F250 with the 460 would it bolt up/work? Just to make sure nothing in trans broke and I don't ruin a brand new torque converter.
Old Aug 11, 2016 | 09:10 AM
  #34
Lead Head's Avatar
Lead Head
If the converter has the same number of studs to mount to the flexplate as yours, it will work.
Old Aug 11, 2016 | 10:01 AM
  #35
0500757Arf's Avatar
0500757Arf
I'll have to check it out when I get the chance over the weekend, should be a 6 bolt pattern right?
Old Aug 11, 2016 | 02:16 PM
  #36
Mark Kovalsky
The diesel is a 6 bolt, the gas engines were 4 bolt. It's not going to work, sorry.
Old Aug 11, 2016 | 06:26 PM
  #37
FORDF250HDXLT's Avatar
FORDF250HDXLT
how far did it fall?
Old Aug 11, 2016 | 09:28 PM
  #38
0500757Arf's Avatar
0500757Arf
I'm not 100% sure actually, it all happened so fast when it happened. The trans dropped to the floor about 1.5-2 feet on the input side and the output was still up on the frame so the trans was tilted with it's input side pointing toward the ground, the torque converter actually fell off like 10 seconds after it hit the ground so I'm not sure if it took the brunt of the fall which was 1.5-2 feet or just slid off due to the input being pointed down so much...in which case it only fell a few inches.
Old Aug 11, 2016 | 09:32 PM
  #39
0500757Arf's Avatar
0500757Arf
Welp.....so much for that idea then.... now I'm debating on putting a cheap rebuilt/used stock torque converter on it for now and just running the trans into the ground and then starting fresh and beefing up a brand new one rather then spend the time beefing this one up and having it go on me in a few years and just having to redo all the work.
Old Aug 11, 2016 | 09:51 PM
  #40
DieselCamper's Avatar
DieselCamper
I've heard that tranny flushes are horrible for trannys, but maybe that could flush out all of the metal? I don't know. If that would work, it means your tranny is still good
Old Aug 11, 2016 | 10:47 PM
  #41
Lead Head's Avatar
Lead Head
Well, the pump's snout wouldn't have snapped off 10 seconds after it hit the ground, which means the full brunt of the fall must have traveled through the converter, into the pump snout to snap it off, right?
Old Aug 12, 2016 | 10:51 AM
  #42
Mark Kovalsky
That's an old wive's tale. I've also heard changing the engine oil is bad for engines.
Old Aug 12, 2016 | 11:21 AM
  #43
Festus Hagen's Avatar
Festus Hagen
Methanoholic
I've always followed this rule on Automatic maintenance ...
If the transmission is in good shape, flush and changes are good to maintain it's life.
If the transmission is in bad shape, nothing but a rebuild will solve it's issues and a flush could make it worse!
-Enjoy
fh : )_~
Old Aug 12, 2016 | 12:12 PM
  #44
0500757Arf's Avatar
0500757Arf
That's what I'm putting my money on but I also thought maybe it hit the lower bell housing first and then the weight of the torque convert plus trans fluid inside still coming down snapped the shaft and the snapping of the shaft absorbed most of the impact For the torque converter because I feel like if the torque converter was the first thing to hit the ground it would have been pinned down from the weight of the trans and not be able to slide off like it did 10 seconds later.
Old Aug 16, 2016 | 10:44 AM
  #45
0500757Arf's Avatar
0500757Arf
Dumb question but is there any difference between a 1996 F250 4x4 E4OD with the 460 gas motor then a 1995 F350 4x4 E4OD with the 7.3? Besides the torque converter that is.
