Radius Arm Bushings
Old Aug 1, 2016 | 10:18 AM
MattMac's Avatar
MattMac
Radius Arm Bushings
I'm new to classic ford trucks and am hoping you guys can help me out. I'm looking for radius arm bushings for my truck. When I do a part search on NAPA, O'Reilly, etc. a few different styles show up. There are sets that look somewhat similar to the ones on my truck but I'm not necessarily sure the last owner used the right ones. The drive side bushings are completely gone and the others are hanging on by a thread.
Does anyone have a recommendation?
1977 F-150 Ranger XLT 4x4 Long Bed
Old Aug 1, 2016 | 10:27 AM
HIO Silver's Avatar
HIO Silver
Stock height or lifted? Regardless, visit Jeff's Bronco Graveyard... they'll have what you need.
I suggest using polyurethane RA bushings. And since "you're there", the C-bushings should also be replaced since they are likely the same age as the RA bushings... do it once, and do it right.
Old Aug 1, 2016 | 10:38 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1.71" round radius rod bushings (shown as 3B203 in pic at upper right) same: 1966/77 F100 4WD / 1975/77 F150 4WD / 1966 Bronco from serial number 788,001 / 1967/77 Bronco.
Old Aug 1, 2016 | 10:44 AM
MattMac's Avatar
MattMac
Thanks, are they symmetrical in front and behind the mount or are the front larger than the rear? Both types are showing up.
Old Aug 1, 2016 | 10:56 AM
MattMac's Avatar
MattMac
Thanks guys, Got it, the different sizes are poly vs rubber with a spacer.
Old Aug 1, 2016 | 11:08 AM
NumberDummy
All 4 (2 right; 2 left) 1.71" long radius rod bushings are the same: Ford part number: C6TZ-3B203-B
Old Aug 1, 2016 | 11:24 AM
MattMac's Avatar
MattMac
Got the full kit. "Includes C-bushings, trac-bar bushings and strut arm bushings."
I assume the "strut arm bushings" are the radius arm, the pictures seems to be identical.
Item 23000 - 1973-1979 Ford Bronco and F Series Truck C-Bushing Kit, 2 Degree Black
Old Aug 1, 2016 | 12:17 PM
NumberDummy
Be aware that 1978/79 F150 4WD's (except Super Cabs) and Bronco's use different radius arm bushings than 1966/77 F100 4WD's; 1975/77 F150 4WD's and 1966/77 Bronco's.
These vehicles used D8TZ-3B203-A Radius Arm Bushings. 1966/77's used C6TZ-3B203-B Radius Arm Bushings.
1978/79 F150 4WD Super Cabs have leaf spring front suspension.
Old Aug 1, 2016 | 12:23 PM
MattMac's Avatar
MattMac
Thanks, being a '77 4WD I should be okay, right? It will still fall into the majority? Out of curiosity, do the 2WD 66/77 F150's use different bushings or are they all the same until '78?
Old Aug 1, 2016 | 12:35 PM
NumberDummy
Being a '77 4WD I should be okay, right?
It will still fall into the majority. Out of curiosity, do the 2WD 66/77 use different bushings or are they all the same until 1978?
1978/79 F150 4WD & Bronco use different radius rod bushings.
1965/75 F100/250 2WD & 1967/75 F350 use different bushings than 1976/79 F100/350 2WD. 4WD's use different bushings.
Old Aug 1, 2016 | 12:40 PM
MattMac's Avatar
MattMac
Got it, I was just wondering if 1966/77 4WD are the same radius rod bushings as 1966/77 2WD.
Old Aug 1, 2016 | 12:52 PM
NumberDummy
C6TZ-3B203-B .. Radius Arm Bushing.
1966/77 F100 4WD & Bronco; 1975/77 F150 4WD
C5TZ-3B203-B Rear & C5TZ-3B203-C Front .. Radius Arm Bushings.
1965/75 F100/250 2WD; 1967/75 F350.
Notice in the F100/350 2WD pic of the 3A360 radius arm (left side shown)...that the 3B203 front bushing is a different shape than the 3B203 rear bushing.
Old Aug 1, 2016 | 01:00 PM
MattMac's Avatar
MattMac
Ah, yeah. Those are the other version I've seen out there that were confusing me. I ordered the correct ones. From that picture it looks like a previous owner of my truck put the 2WD version on, must be why they got destroyed so easy.
Thank you for the help, learned a lot in this thread. I'll post back when I have it all fixed up.
dcelrod
Apr 4, 2016 06:34 PM
'94IDITurbo7.3
16
Jul 2, 2012 07:13 PM
2classics
Offroad & 4x4
Sep 18, 2006 03:12 PM
OffRoadF-150
Offroad & 4x4
Jan 4, 2006 01:32 PM
pipefitterpro
Aug 12, 2003 05:53 PM
