Gas treatment
Old Jul 31, 2016 | 09:30 AM
clark grizwald's Avatar
clark grizwald
Gas treatment
What do i need to do with the gas i put in my original 1954 straight 6? Lead additives? What about the ethanol?
Old Jul 31, 2016 | 10:36 AM
FortyNiner's Avatar
FortyNiner
If the truck has been updated for corn gas, just hit the filler tube cleanly with regular unleaded and enjoy the ride. Ethanol free is better - not just for your old ride - but not always available. Lead additives do not contain lead. Many are fans of Marvel's Mystery Oil for both the crankcase and gas tank.
Old Jul 31, 2016 | 10:47 AM
ALBUQ F-1's Avatar
ALBUQ F-1
I suspect that 223's didn't have hardened valve seats?
Old Jul 31, 2016 | 02:42 PM
Cougar54's Avatar
Cougar54
I'm guessing my 226 doesn't have hardened exhaust valve seats either so I need a lead substitute as well. Anyone have a favorite that is not too hard to obtain?
Old Jul 31, 2016 | 02:57 PM
Tedster9's Avatar
Tedster9
Unless you're planning heavy towing at highway speeds in your truck a lot of people say there is no need for hardened valve seats. An engine of that era may be OK in fact, they used good steel back in the day.
A straight six kept at reasonable RPM and lighter duty should be fine. Testing found the lead subs don't do much, are expensive, and need to be double dosed or more to work at all.
Old Jul 31, 2016 | 03:49 PM
ALBUQ F-1's Avatar
ALBUQ F-1
"Lead substitutes" are just oil, they do nothing good. Your 226 should have stellite seats on both valves. Ford began phasing them out in '51, when they went to rotators (on the V8's at least).
That's what I've always heard, too. But I think that advice was "pre-ethanol". See here: https://www.ford-trucks.com/forums/1...ab-owners.html
Old Aug 1, 2016 | 10:40 AM
CharlieLed's Avatar
CharlieLed
I saw this fuel additive featured on some automotive program on TV and thought I would give it a try...I have been running it in all my vehicles ever since (~12 mos). It really works great on counteracting the adverse effects that methanol has on the fuel system. Many others who I have spoken to about this additive have also run it with good results.
https://www.amazon.com/Star-Tron-Enz...words=startron
Old Aug 2, 2016 | 06:25 AM
pbsdaddy's Avatar
pbsdaddy
While on this subject, did anyone else read the article regarding the use of diesel oil in the older engines? It seemed like a good argument for it's use. Is/has anyone using/used it?
Old Aug 2, 2016 | 07:27 AM
Cougar54's Avatar
Cougar54
I heard the same thing about diesel oil and found it interesting that the owner of Fantom Works out of Virginia (the show is on Velocity) finished rebuilding a 50's vehicle (I'll be darned if I can remember what kind) but the owner asked what type of oil to used in his newly rebuilt engine and Dan told him to use a 15W40 diesel oil and to ignore the "diesel" designation. I plan on my next oil change to use it myself.
Old Aug 2, 2016 | 01:45 PM
Mixer man's Avatar
Mixer man
Interesting treatise on gasoline and tetraethyl lead.
http://www.walshcarlines.com/pdf/mec...ations.d4e.pdf
Old Aug 2, 2016 | 02:00 PM
JPMallory's Avatar
JPMallory
I've been running 15w40 diesel oil in my 48 (flathead v8) for a couple years now. So far, so good.
Old Aug 2, 2016 | 02:12 PM
Mr. Ed's Avatar
Mr. Ed
If memory serves me, diesel oil has zinc in it which is why so many folks like it and use it in break in mode.
Later!
Mr. Ed
Old Aug 2, 2016 | 02:33 PM
Mixer man's Avatar
Mixer man
I use Chevron Delo 400 15w-40 in the dozer, skid steer, excavator, the '08 Powerstroke, and the 254 cu. in. gasoline engine in the mixer.
Truth revealed about lube oils:
http://www.api.org/~/media/files/cer...2515.pdf?la=en
Old Aug 2, 2016 | 04:39 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Note that that paper is about unleaded gas, not E-10. E-10 adds some concerns.
Later!
Mr. Ed
As I recall, CJ-4 was the last diesel oil to maintain high zinc levels, it was reduced after '06.
Here's an interesting perspective from a GM Fuels and Lubrication engineer: http://www.nonlintec.com/sprite/oil_myths.pdf
Old Aug 2, 2016 | 04:56 PM
3twinridges's Avatar
3twinridges
I have been running non-ethanol 87, no additives, for two weeks now. Truck has never started as good as now plus it seems I have lost a slight hesitation off idle. Big bonus seems to be no soot on first start.
