Codes and alarms everywhere!!!!
Old Jul 30, 2016 | 08:35 PM
70T351W's Avatar
70T351W
Pulled into the yard today after about a 20 mile haul with my 2015 f450 6.7.
I shut it down after pulling in, from what i knew evrything was fine. 20 minutes later i started it codes and lights went off like the four of july. A wrench light, oil light, temp light and maybe even an obama light. The gauges did not even move. I shut it down, let it cool then after starting it only the CEL came on. WTHeck!!! bought two new trucks in 2015 and both had front end alignments off. The f450 doors fill up with water when it rains. One day after a rain I put my seat belt on and the seat belt was soaking wet. The cab corner where the seat belt spools up was full of water. The tie rods and ball joints started making sounds after 20k miles so i checked them to find they didn't have ANY grease in them!!!! The def fill tube broke off driving through a small dip in the road (i heard it pop). WTHeck!!!!! my first new truck....glad i stihl have my 96 7.3.
Old Jul 30, 2016 | 09:46 PM
jvgviper's Avatar
jvgviper
Check under parking brake for a bundle of wires connected with a gray and black connector. Push these connectors tight as hard as you can. I
Old Jul 30, 2016 | 11:11 PM
twigsV10's Avatar
twigsV10
I have never owned a truck with a warranty but have had ag machinery with and would assume an 2015 F450 would still be under warranty. If this is true take it to the dealer but don't go in kicking and screaming, just calmly tell them the problems and that you ARE NOT going to be satisfied until they are fixed.... Then call every single day at random times and ask nicely how the repairs are going (you don't want him to figure out your game and be conveniently out of the office when you call) and your truck will not be put on the back burner of the dealerships agenda, it will get fixed ASAP in my experience.
The squeaky hinge gets the oil, the annoying piece of junk gets put in the back and forgotten...
Old Jul 31, 2016 | 12:15 AM
14SD4Jeffro's Avatar
14SD4Jeffro
2016 F350 SCREW 4x4 PSD 5400 miles
7/20, while pulling into a parking spot at work, got the bells & multiple alarms (advance track, oil, coolant, etc), along with a check engine light. Shut off truck, restarted & all alarms/messages were gone & check engine light was off.
7/23, worked an overnight shift & everything was fine with truck when I got off work...went home, changed clothes, grabbed my cameras & my daughter & headed off to our local NASCAR short track. Started the truck & the bells/multiple messages/CEL was back. Stopped at the local O'Reiley's & had them put it on a scanner. showed a 2610, 2615 or some garbage code having to do with the traction system. about 7 or 8 miles from the track, the CEL turned off. got our pit passes, started the truck & no warnings or anything. As we were driving into the pits, I got all the multiple messages as before, with the addition of all my guages showing dashes. Parked, shut it off & attempted to restart, but absolutely nothing.
one of the local racers, who is a service tech suggested it may have been an alternator issue, with the voltages in teh batteries dropping so low in voltage that the computers got "confused" & began throwing multiple codes. attempted to connect a battery charger, but both batteries were full. decided to disconnect battery terms & HOPE that enough of the codes/information would clear & that I"d at least be able to get my truck home.
Once the terminals were connected, truck started fine, even though the CEL remained on.
tooK monday 7/24 off & took the truck to the dealer & got my rental.
finally contacted by dealer on friday, 7/29 & picked up my truck this morning, 7/30.
below is a direct quote as to the cause(s) of the problem..if these areas haven't already been checked, might be a good place for the clueless mechanics to start:
"IDS hook-up. KOEO and KOER tests. Many, many network codes and lack of data codes. Pinpoint tests. Access Kick panels and under dash. Wiggle tested wiring while running network tests and monitor PIDS. isolated the concern down to C210 splice S102 or S377. Accessed and replaced both splices and over C210. Reassembled and retested. Passing at this time."
hopefully, this will be the end of the problems, though the final 3 words of the report aren't that encouraging to a customer
hope this helps, if even just a little
Old Aug 5, 2016 | 09:19 AM
golfmedik's Avatar
golfmedik
My dealer's tech told me about this very thing last week. A shame that loose wires in the fuse box could disable the truck. Said he's done 5 in July.
Old Aug 5, 2016 | 08:16 PM
Randy Klauk's Avatar
Randy Klauk
Something similar happened to me 3 days ago. While pulling out of a parking lot the warning chimes started up and warning messages on the display: Low oil pressure, High tempeture and Service Advance Trac, there may have been more. All gauges were shut down and the turn signal lever would not cancel after a turn. I made it to the local dealer, shut it down and went in to talk to the service writer. When he started the truck up everything was working but the check engine light was on. I left it and picked it up the next day. Here is what the RO notes:
Verified cust concern clear codes, found check engine light came on
KOEO:P2610:00-EC check oasis found SSM:44707, check for
PCM updates reflash PCM:EC3A-12A650-DJ,TCM:EC3A-12B565-DC,
UPDATED MODULES CLEAR CODE TEST DROVE RERAN KOEO
PASS
I copied this just as it appears on the RO.
The tech stopped by as I was getting my keys and corrected the service writers explanation (he said there was a TSB, I asked him for the number)
the tech said it wasn't a TSB but a SSM.
I'm not sure what was done and I don't know what SSM stands for.
It was pretty spooky when almost everything on the display was wacko, for lack of a more technical term.
Randy
2014 F250 CC LWB Lariat
cay5628
6.7L Power Stroke Diesel
21
Jun 17, 2017 01:32 PM
Rose Clifford
Aug 11, 2012 08:45 PM
WonderDonkey
Aug 13, 2007 07:22 PM
fellro86
General Automotive Discussion
21
Nov 4, 2006 03:15 AM
D2EBMA
Mar 1, 2004 12:24 PM
