56 Panel Lowering Questions
Old Jul 30, 2016 | 06:30 AM
Dirt Boy's Avatar
Dirt Boy
We started this project 10 years ago. We've moved since then and once Minty was back on the road we discovered she doesn't fit in the garage in our new place; she's 4" too high. I'm looking at the kits that drop her 5". I thought about adding sway bars as well.
How will this change the ride? Handling? Clearance problems?
Also, while I'm at it, any suggestions for good shocks.
Thanks
Old Jul 30, 2016 | 07:11 AM
52 USCG Panel's Avatar
52 USCG Panel
My panel appeared to be a little too high for my garage as well. The opening is 83 inches tall, but I wasn't able to use that full height because of the adjustment of the door. With a little trial and error adjustment, however, I was able to get the door to fully retract. With the door fully retracted, my panel just fits. The magic number for door height, at least for a stock 52', is 83 inches. Congratulations on your truck! It's a beauty.
Old Jul 30, 2016 | 08:07 AM
Dirt Boy's Avatar
Dirt Boy
Well, USCG, I went out with tape measure in hand and ......... you are right, with a little redesign of the garage door I can get 83.5" clearance. Thanks for pointing me in that direction. The 56 may be a tad taller but I'll measure twice before the first cut.
burnettd01
13
Mar 8, 2018 10:30 PM
GeneGregory
Jul 12, 2015 07:46 PM
idtoy
Nov 4, 2012 12:00 AM
Itch71
Nov 18, 2007 04:07 PM
Pud12343
Aug 18, 2007 12:31 AM
