FE HEADS
Old Jul 29, 2016 | 06:57 PM
72CC428's Avatar
72CC428
FE HEADS
I know that the heads are identical, but can you swap sides? I'm really not sure which is which since I did the valves. I have two bolts sticking out of one and that's what I was using to separate I.D. them but I think I may have taken them out and possibly put them in the wrong one.
I would have put this in my build thread but I wanted as many eyes on this ? as possible. My build isn't exactly sexy and it is kind of boring compared to the others in this forum.
Old Jul 29, 2016 | 07:07 PM
Jklnhyd's Avatar
Jklnhyd
Im pretty sure the difference is the water passages?
Old Jul 29, 2016 | 07:41 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
FE heads are the same right & left.
Old Jul 29, 2016 | 09:46 PM
72CC428's Avatar
72CC428
Can you swap sides though?
Old Jul 29, 2016 | 09:51 PM
Coastal68's Avatar
Coastal68
If they're identical then you can swap them. Is there some other sense in which you mean "swap sides?" Not trying to be a smart alec, just trying to understand your question.
Old Jul 29, 2016 | 10:20 PM
ultraranger's Avatar
ultraranger
Maybe this is a better way to explain it. The heads are not side specific. Either head will work on either side of the engine. There is no left or right cylinder head.
Old Jul 29, 2016 | 10:27 PM
KsHighboy's Avatar
KsHighboy
They are not side specific, however, make sure when you put the rocker assembly back on that the long rocker bolt goes in the hole with the oil hole next to the bolt hole.
Old Jul 29, 2016 | 11:08 PM
72CC428's Avatar
72CC428
OK
Thanks Kshb.
Thanks guys. I was worried that since it is a engine with about 40,000 miles on it I might need to keep the heads on the original sides.
Old Jul 29, 2016 | 11:13 PM
Ford_Six's Avatar
Ford_Six
Nope. Just prep head and block surfaces according to gasket manufacturer's specs, and rock on.
Old Jul 31, 2016 | 07:35 PM
72CC428's Avatar
72CC428
Cool! Thanks again!!
Old Jul 31, 2016 | 08:07 PM
351Cleveland C4's Avatar
351Cleveland C4
Just be sure you don't put them on backwards....
Old Aug 1, 2016 | 12:49 PM
72CC428's Avatar
72CC428
Or upside down. Except in Australia...
Old Aug 1, 2016 | 12:50 PM
351Cleveland C4
^ right!
Old Aug 1, 2016 | 12:51 PM
Coastal68's Avatar
Coastal68
LOL! That's just mean.
Old Aug 1, 2016 | 01:42 PM
Brian1971f100's Avatar
Brian1971f100
I think that the gaskets need to be installed so that the water jackets do not get blocked off. If I remember correct there have been threads here regarding this and overheating problems
