AC clutch
Old Aug 1, 2016 | 02:28 PM
TooManyToys.'s Avatar
TooManyToys.
If the problem is a slipping clutch there will be wear of both the friction disc, and the opposing surfaces, the plates. If the problem is a slipping belt, then there will be belt wear. For me there any squeal, I just noticed that the A/C wasn't effective a higher RPMs. Went to airflow only until I got home and checked the gap first due to 200k miles of service. I know you homed in on the clutch, and the gap is always the first thing to check, but belt or bearing could also be in the check mix.
dodgens
Jun 14, 2019 06:42 PM
96_F250_Deezal
Sep 27, 2016 01:27 PM
evan1242
Jun 19, 2015 09:03 PM
bleeds blue
Oct 7, 2012 08:45 PM
MitchPeters
1997 - 2003 F150
Jul 23, 2008 10:12 AM
