To pull the brake/clutch pedals,pull steering too ?
Not if you are just changing out the pedal arms. Not sure why you would need to take off the entire bracket.
I beleive there is a single pin that goes through the clutch and brake pedal with a cotter pin on one side holding it in place. It can be a real bugger trying to get to those components up under the dash.
The truck was a 4 speed but the guy never put in the auto brake pedal. I am putting it back to stick shift. All the parts from a doner 79 are going in so I know they are correct. It was a real mainer hack job! Thanks
Unless they did something to bracket, it should be no different than the 1 out of the 79. You should still only need to swap the pedals.
I want to swap the whole assembly because my truck was jerry riged when I bought it. Instead of finding the correct pedals to match the brake booster they welded a exstension up on the pedal where the whole is for the booster rod. It's a mess. I want to change the whole set pedals, brackets and booster out of a doner 79 truck.
Drac
05-16-2013 09:03 AM
nothercrash
12-10-2011 07:36 PM
CaptainIPSC
11-03-2008 08:35 PM
TXSILVERADO1
05-07-2008 04:37 AM
