Gas Tank Strap Bolt question!
Old Jul 27, 2016 | 03:14 PM
df85732's Avatar
df85732
When I pulled my rusty ole gas tank I found that the straps holding the tank hinged on the running boards on one end and was attached with a couple of bolts on the other. Of course these two bolts were rusted and I had to cut them off with a grinder. It looks to me that these two bolts were put in before the strap was was made, bent, and welded. My question, what or how can a put a bolt in it's place to replace it? There is not enough room to insert a new bold the same size. Any ideas out there? Thanks, Dave
Old Jul 27, 2016 | 05:42 PM
toby tough's Avatar
toby tough
Not familiar with your strap there but if there are some spot welds in it maybe you can cut them out, get your new bolt in, and plug weld the strap back together.
Old Jul 27, 2016 | 06:53 PM
drptop70ss's Avatar
drptop70ss
If it is a bolt you want to put into a spot where you cannot get behind it you can cut a slot next to the hole so a carriage bolt can slide into the hole.
Old Jul 27, 2016 | 07:09 PM
Harrier's Avatar
Harrier
Or you can do what I did. I drilled out the welds and replaced them with bolts.
Old Jul 27, 2016 | 07:41 PM
df85732's Avatar
df85732
Thanks for "blazing the road" ahead of me Joe! That's just too easy. Are you still headed to Lincoln to move your daughter this weekend? If you still need a hand I should be around Friday afternoon or Saturday morning!
rvpuller
All Things Towing
Jun 16, 2018 11:26 AM
green_95
Apr 9, 2017 10:27 PM
carbo_nero
Mar 10, 2017 07:58 AM
9inchlift87
Feb 18, 2012 06:52 PM
Patrick8475
1978 - 1996 Big Bronco
Aug 25, 2003 02:22 PM
