Code 558 won't go away
Old Jul 26, 2016 | 11:10 PM
Kumank's Avatar
Kumank
So I recently purchased a 95 302 f150. I live in California and need to smog the vehicle due to buying it as is. I have done a lot of work so far and have gotten rid of most of my codes but I cannot lose the 558. I have replaced the entire vacuum system, I replaced the EVR, replaced O2 sensor, replaced CANP solenoid, cleaned and tested (sucked on a vacuum line and engine bogs and almost dies), cleaned my throttle body, cleaned the egr down tube into the manifold. I need to get this CEL off my dash to smog it. Anyone have any ideas?
Old Jul 27, 2016 | 07:49 AM
subford's Avatar
subford
The 558 is a failed electrical circuit code.
TC 558 indicates a failure in the EGR Vacuum Regulator (EVR) solenoid circuit.
Possible causes:
-- Damaged EVR solenoid.
-- Open harness.
-- Shorted harness.
-- Damaged Powertrain Control Module (PCM).
nijwnfi
Escape & Escape Hybrid
Jun 10, 2017 10:05 PM
cjharvey2000
Mar 8, 2016 10:06 PM
BigB1975
Feb 28, 2014 07:35 PM
Cessnadriver
1997 - 2003 F150
Jun 19, 2007 10:35 PM
blue302
Oct 18, 2003 09:01 AM
