Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
401 code fix
Old Jul 25, 2016 | 09:00 PM
nijwnfi's Avatar
nijwnfi
401 code fix
Got a lot of help here over the years, thought I would throw this in. 01 Escape throws a 401 code week before emissions of course. Checked DPFE sensor first, signal was bad. Replaced sensor, but problem returned. After checking EGR valve which was OK, moved on to the vacuum control solenoid. Hooked a vacuum gauge to the line going to EGR valve and went for a ride. No vacuum to EGR. Checked vacuum lines to the vac control and found the little red one melted most of the way through. When it melted it sealed itself off so no vacuum leak or rough idle. Problem now fixed, hope this helps someone.
Old Jun 10, 2017 | 10:05 PM
ferretface's Avatar
ferretface
I don't have this code show up yet, but I'm curious as to what code reader you're using - is it an Actron? If so, what is the model number?
I have the Actron ODB-II CP9135 but it gives an error message and won't link...
Dre82s
Jun 15, 2010 11:46 PM
f100guy
1997 - 2003 F150
Jan 17, 2009 09:37 AM
ynot2244
Sep 28, 2005 10:35 AM
Zugget
Feb 4, 2004 07:40 PM
JTD1972
1978 - 1996 Big Bronco
Jun 17, 2003 09:47 AM
