Low Compression -- '66 240
Old Jul 26, 2016 | 10:26 AM
BusterB's Avatar
BusterB
I have a recently acquired 1966 F100, with a 240 manual and Autolite 1bbl. It ran well enough for the first month, but recently was backfiring and sputtering and couldn't hold an idle well or at all. Now, it'll turn over, but to get and stay running the gas pedal needs a lot of attention. I took apart the carburetor and rebuilt it, adjusting the float in particular which seemed to have been out of whack. Still didn't fix the problem, and a mechanic checked the compression which seems to be low (in the 50s) across all the cylinders.
What should be the next step? Valve adjustment? Just trying to figure out how serious of a problem this may be in order to get the truck running dependably.
Thanks.
Old Jul 26, 2016 | 06:40 PM
john jamieson's Avatar
john jamieson
What condition are your plugs, wires, points, rotor, condenser, and cap? People have reported a lot of problems with cheap condensers failing.
john
Old Jul 27, 2016 | 09:52 AM
kjvforme's Avatar
kjvforme
Sounds like she is worn out. Might need a ring job, or a full rebuild. What have you got for oil pressure?
gavin68
Jan 27, 2018 04:50 PM
ldwaldon
Oct 25, 2010 09:12 PM
cervantes
Oct 19, 2009 04:55 PM
79FordBlake
17
Aug 20, 2009 08:36 PM
Boxcar2282
Flathead V8 & Flathead 6
Aug 9, 2006 09:09 AM
