Code 32 Info Needed
Old Nov 7, 2003 | 11:47 AM
Zugget's Avatar
Zugget
Code 32 Info Needed
Can anyone give me details on code 32 of my 87 Bronco. It only comes up as a continuous code and not during the engine run test or Key Off Key On test. I think it has something to do with the EGR posistion sensor on top of the EGR valve. The valve is working properly because I can see it move up a little during the engine run test. I also teed in my vacuum gauge and went driving, got plenty of vacuum during cruising speeds. Thanks.
Old Nov 7, 2003 | 12:37 PM
DanTana's Avatar
DanTana
http://autorepair.about.com/library/ts/bl-dtcs-29.htm
Code 32 is EGR not Controlling. Could be the vacuum device that sends the vacuum to the EGR?
Old Nov 7, 2003 | 03:04 PM
Zugget's Avatar
Zugget
It could be, but I know the EGR vacuum valve is working. It pulls vacuum during the Engine Running test and also while I am driving. Do you have a Ford description for that code?
Old Nov 7, 2003 | 06:52 PM
DanTana's Avatar
DanTana
To test the EGR you have to first unhook the IAC, then pull a vacuum to the EGR and if it's opening the engine will begin to stumble. Do this at idle speed. There should be no vacuum to it at idle from what I have read. Unhooking the IAC will prevent it from compensating for the air so it will act like a vacuum leak.
Old Nov 7, 2003 | 07:05 PM
circledirt's Avatar
circledirt
That sensor on top of the egr valve goes bad and misinforms the ecm that egr not opening when it is.
Old Nov 7, 2003 | 10:41 PM
Zugget's Avatar
Zugget
If the EGR sensor wasn't working, the Engine Run test would catch that because it trys to open the EGR valve during the test. I can see it open and I get good vacuum to the switch. The more I think about it maybe the sensor has a dead spot in it. I checked the resistance on it and its linear as can be.
Old Nov 8, 2003 | 08:09 AM
DanTana's Avatar
DanTana
Here's another thought...there is a MAP sensor on the firewall, it sends the vacuum to the ECM which then in turns opens the EGR. That might be it.
Old Nov 8, 2003 | 11:30 AM
circledirt's Avatar
circledirt
That sensor is probably failing only part of the time. It,s plastic, sitting on top of a metal valve that has 1000 degree exhaust gas flowing thru it. I couldn,t begin to count how many I,ve replaced for exactly the same problem.
Old Feb 4, 2004 | 07:40 PM
cougar86's Avatar
cougar86
circledirt: did you also experience rough acceleration as if the timing was not advanced enough? My timing is dead on at 10 degrees BTDC and the only code that I get is code 32.
