302 from car that doesn't exist
Old Jul 25, 2016 | 04:23 PM
hharris8's Avatar
hharris8
I have a 1986 ford bronco with a engine I believe has been replaced. I removed the starter and looked at the engine number and it is D9OE-6015-E. That decodes as a 1979 ford Fairlane(all) and Torino 1967-1976. The Fairline's were only produced till 70 and Torino was only produced till 76. I can't find any websites that I can enter this engine and bring up all of the parts. What am I missing?
Old Jul 25, 2016 | 05:18 PM
hharris8's Avatar
hharris8
I've done some more research and it looks like its a LTD II engine with those numbers.
Old Jul 25, 2016 | 06:28 PM
Conanski's Avatar
Conanski
The casting numbers on these ford engine parts only tell you what division that part was manufactured for, it does not tell you what division eventually used that part to build an engine or what vehicle it was installed in.
Old Jul 26, 2016 | 06:59 PM
baddad457's Avatar
baddad457
As Conanski said, the casting numbers are in no way indicative of what that block was used in from the factory. If this is a 351W block, it could be the original block to that truck. If it's a 302 block, then it's not the original block. The E0AE block replaced that in 1980. And the E0AE was replaced in 1985-86 by the roller blocks.
little jo
1966 - 1977 Early Broncos
Mar 5, 2021 09:04 AM
vortech
Aug 7, 2008 08:09 AM
lakecityg
Mar 16, 2006 03:31 PM
atdoman
Oct 4, 2005 09:00 PM
bootie
Nov 2, 2004 08:08 AM
