T19 squeaking? With video
Old Jul 25, 2016 | 03:47 PM
SpencerS's Avatar
SpencerS
So I took a video of the squeaking sound my truck makes while coasting in gear. Sorry if this is some super common thing that I somehow have not known. Thanks!
Video:
https://youtu.be/vx-KUbVHvv0
Old Jul 25, 2016 | 04:15 PM
FuzzFace2's Avatar
FuzzFace2
Bad Ujoint(s) is what I think I hear. Like a chirping sound.
Does it make the noise when taking off from a stop? Most of the time bad Ujoints make that chirping sound from a stop and getting up to speed.
If the joints can be greased try that to see if it stops making the noise. If it does stop then you know what the noise was but they need to be changed as the damage is done.
Dave ----
https://www.youtube.com/watch?v=vx-K...ature=youtu.be
Old Jul 25, 2016 | 04:20 PM
maytag906's Avatar
maytag906
Lots of ambient noise, hard to tell. I did hear what sounded like universal joints at the end.
Old Jul 25, 2016 | 09:32 PM
SpencerS's Avatar
SpencerS
I've taken your responses and am running with it; took off my entire driveshaft and am replacing all three joints. Which is quite the pain. I might have a shop properly install the new joints so i don't screw them up
Old Jul 25, 2016 | 09:39 PM
rowdyredneck's Avatar
rowdyredneck
Sounds like a u joint to me as well.
Old Jul 26, 2016 | 03:27 PM
Braggs's Avatar
Braggs
I did mine on the kitchen table so you should be able to handle it. Just need a couple 2x4s and a big hammer (or a big socket underneath works good too). Plus I watched a youtube video on how to install/remove and where to hammer it so you don't break something.
Old Jul 27, 2016 | 04:41 PM
SpencerS's Avatar
SpencerS
Well, got it all back together by myself, somehow, and it doesn't make the noise anymore! Y'all found the problem, thanks a bunch! 😃
Old Jul 28, 2016 | 06:43 AM
FuzzFace2's Avatar
FuzzFace2
Good to hear it's fixed.
Did you find any of the caps with rust in them or would not flex smoothly?
If so then that was the one making the noise.
Dave - - - -
Old Jul 28, 2016 | 10:28 AM
SpencerS's Avatar
SpencerS
Yes, there was even one that had no more rollers, just dirt. And it was red. Another looked like the rollers were stuck, and they all looked pretty old
Old Jul 28, 2016 | 11:11 AM
FuzzFace2's Avatar
FuzzFace2
yep then that was it.
Good job
Dave - - - -
02GrayPowerStroke
Oct 15, 2010 08:26 AM
Mecac
1997 - 2003 F150
Jul 27, 2009 02:18 PM
jater76
Apr 17, 2007 10:50 AM
power_speed
Dec 9, 2006 01:17 PM
AK77
May 15, 2002 03:37 PM
