weird fead engine noise
Old Jul 24, 2016 | 06:49 PM
str8sixman's Avatar
str8sixman
seems to be coming from the fan clutch area when its idling.....it sounds like a metallic rattling sound. I took the shroud out and got access to the fan. it seems that where the wire harness goes into the fan clutch, there is a metal cover around the outside of it, and its loose around the harness. anybody ever seen this? or is there a way I could tighten it up so it quits ratteling or am I looking at a new clutch? thanks
also the clutch seems to be fine, its locking up when it should and not making any noise off idle
Old Jul 25, 2016 | 02:12 PM
mattdoc88's Avatar
mattdoc88
I had the same issue. I replaced my clutch and it was fixed. I'm pretty sure there's no way to fix the clutch you have.
If the wires come loose, they'll get caught in the fan and that would be bad while driving.
Rock auto had the best clutch price at the time. Fyi the snow plow option clutch is only different from the standard clutch in its lowest state of lockup (like unlocked but it still spins some). This is because if you have a plow it blocks airflow. So its not an upgrade unless you plow.
Old Jul 25, 2016 | 02:17 PM
mattdoc88's Avatar
mattdoc88
Here is my thread on the issue, with a video so you can listen to tell if it's the same sound.
https://www.ford-trucks.com/forums/1...-included.html
cnice_37
18
Jan 19, 2016 07:55 PM
ryanelwood
Jan 22, 2013 01:11 AM
Norfra
1997 - 2003 F150
Oct 25, 2007 10:24 PM
mark a.
Dec 27, 2004 11:50 AM
imwebcrazd2
Aug 18, 2004 03:47 PM
