Sponsored by: Real Truck
Jack Stands - What Size?
Old Aug 18, 2003 | 08:12 PM
F250reddog's Avatar
F250reddog
This is a stupid question, but before I made the purchase I wanted some feedback. I'm looking to purchase some jack stands to work on my Truck (1999 F-250 SC). What size should I be looking at? The Sears Craftsman Jack stands I saw the other night come in 2, 2 1/4, 3, 3 1/2, and 6 ton. Considering that I will mostly be using the stands to lift only half (front OR back) of the truck at a time which size do I want? Thanks for the input.
Old Aug 18, 2003 | 08:19 PM
99f350sd's Avatar
99f350sd
I have 4 6ton units. I would not get anything smaller as I use mine all the time and they are about right..
Old Aug 18, 2003 | 08:56 PM
02superstroker's Avatar
02superstroker
ditto
Old Aug 18, 2003 | 09:39 PM
F250reddog's Avatar
F250reddog
Does that mean I need a 6 ton floor jack as well, even if I'm only lifting one wheel at a time?
Old Aug 18, 2003 | 09:46 PM
DCSpecial's Avatar
DCSpecial
I have four 6 ton stands as well.............sometimes I wonder if the 12 tons (I'm pretty sure that's what they were) would have been better for the extra height .
I've used a 3.5 ton floor jack to lift it up.
Old Aug 19, 2003 | 07:59 AM
kehale's Avatar
kehale
I've got two 12 ton jack stands from Harbor Freight tools.
They're great (but not tall enough for my truck's 12" lift)
-T
Old Aug 19, 2003 | 08:37 PM
02superstroker
reddog.. no it does not. I use a 3 ton jack and it works fine... i can lift the rearend up from the center of the dif with it no problem. I dont leave it on it by any means, but long enough to get the stands under. On the fron of the truck i use two 3ton jacks, one on the dif, and the other on the oppostie side just on the axle.
Old Aug 20, 2003 | 10:45 AM
F250reddog's Avatar
F250reddog
Just to be sure... are you guys recommending the 6 and 12 ton stands because of their height or their weight capacity. I found a 3 ton stand set that has a 20" lift capacity. I believe this is enough height but is it enough weight capacity?
Old Aug 20, 2003 | 10:49 AM
kehale's Avatar
kehale
Should work fine.
-T
Old Aug 20, 2003 | 09:51 PM
99f350sd's Avatar
99f350sd
6 ton 12,000 pound stands don't get anything less...
Rob89
Jul 17, 2017 08:43 PM
P4IN COMM4NDO
16
Sep 26, 2016 12:02 PM
jasonodsky
Sep 21, 2016 09:33 PM
89F250_7.5
Aug 14, 2009 02:28 PM
texastech_diesel
General Automotive Discussion
Dec 2, 2008 09:48 PM
