2005 6.0 no start
Old Jul 23, 2016 | 11:09 PM
BLADE35's Avatar
BLADE35
Originally Posted by FrankNBeans
I
The two fault codes are for ICP and Crankshaft.
Mike
Post the Exact DTC
How did all this start going down theres a lot going on here
Give us the long story
Old Jul 23, 2016 | 11:19 PM
BLADE35's Avatar
BLADE35
Originally Posted by BigGreenEx
This is for my own curiosity:
If the ICP is reading pressure wrong, wouldn't the truck still start if the IPR is being commanded to 83%? ?
PCM has to see that 500psi before it turns on injectors so it looks Directly at ICPV
ICP has 5volt V-ref for quality control
IPR isn't monitored for quality Directly at the valve so it wont use its value like that
Plus its not programmed that way and cant be programmed that way really by operating characteristics
Can pressure in extreme excess of 500psi result in a no start also?
it would start until the IPR or something blew out
Old Jul 24, 2016 | 12:27 AM
FrankNBeans's Avatar
FrankNBeans
I'm aware of the 6.4 starter spinning faster, it wasn't in stock when I bought the replacement starter. What is the normal starting RPMs?? I'm only getting 150-170
Old Jul 24, 2016 | 01:10 AM
FrankNBeans
Here are my fault codes;
P2285 ICP sensor circut low
P2614 Camshaft position signal output circut/open
P2617 Crankshaft position signal output circut/open
Old Jul 24, 2016 | 01:15 AM
FrankNBeans
My 6.0 has been flawless until I started having the crank no start when hot issue. After the truck would cool down it would start. I'm guessing I need stand pipes and dummy plugs. I never got around to installing those and excessive cranking killed my FICM. So I had my FICM repaired by Ed, bought a new alt, new batteries, new 6.0 starter.... Now I have the Torque Pro app for PIDs.
Old Jul 24, 2016 | 01:24 AM
FrankNBeans
Old Jul 24, 2016 | 08:21 AM
BLADE35's Avatar
BLADE35
Sounds like your on Track here
Was the ICP DTC there before you unplugged it
does CMP/CKP sync during crank
Old Jul 24, 2016 | 11:30 AM
FrankNBeans
Yes, ICP fault code was there before I unplugged it.
I don't have CMP/CKP sync on my torque pro app, yet. Anyone know how to set up the Torque Pro to monitor that??
Old Jul 24, 2016 | 11:47 AM
jmaskew's Avatar
jmaskew
I would remove the FICM relay until you resolve the HPOP issue or else you will be sending the FICM back to Ed. All that cranking will end up killing it again.
Old Jul 24, 2016 | 11:52 AM
jmaskew's Avatar
jmaskew
Check out this thread. It has a few equations for Pids.
https://www.ford-trucks.com/forums/1...ew-gauges.html
Old Jul 24, 2016 | 01:51 PM
FrankNBeans
I will unplug the FICM relay so I don't damage the FICM.
Thanks for the link Jmaskew
Old Aug 7, 2016 | 03:45 PM
FrankNBeans
It's cranking between 155 - 175 rpm's. I replaced my starter with a 6.0 starter. The 6.4 starters were not in stock. Hind site, I should have waited for a 6.4 starter since they spin faster.
Old Aug 7, 2016 | 03:49 PM
  #28
FrankNBeans
Yes, cranks between 155-175 RPMs. I put a 6.0 starter in as the 6.4 starter was out of stock.
Old Aug 18, 2016 | 09:06 PM
  #29
FrankNBeans
I was able to remove the passenger side dummy plug. The old (original) passenger side dummy plug has no rips or tears on the O rings. However, they appear to me more flat than the OEM replacement dummy plugs. I put in the new passenger side dummy plug and now trying to remove the passenger side Stand Pipe. It hits the fire shield. Should I remove the stand pipe in 2 pieces?? I would like to put the new stand pipe in (itch has the white washers) because the O rings look flatter than the new OEM replacement O rings. Any thoughts???
Old Aug 18, 2016 | 09:16 PM
  #30
FrankNBeans
Ok, looks like the improvements are only to the top part of the stand pipe. I removed the top part and replaced with the improved top part. Putting the passenger side back together. I will try and start it once put back together. I will report back what happens!!
