starter problem
Old Jul 24, 2016 | 09:47 AM
joezzz's Avatar
joezzz
here are several photos of the starter parts.
I found that it I rotate the pinion gear toward the starter, as it reaches the starter it begins to skip.......I assume that it means time to replace the entire assembly.
Also there is a bushing spacer that is between the starter and the pinion, but I can't find that part listed anywhere.
Old Jul 31, 2016 | 01:13 PM
petemcl's Avatar
petemcl
I have the original starter and a new starter if you need either.
Old Jul 31, 2016 | 02:59 PM
joezzz's Avatar
joezzz
thanks to all
that responded to my starter issue.
After a real close inspection, I realized that 'spacer' at the end of the shaft that the pinion gear rides on at inner most end was threaded. So clean a break that it took a magnifying glass to spot the last vestiges of the thread.
Found new/old part from Bendix, still in the original box.
grayson20
Sep 23, 2016 10:22 AM
CarolinaRanger
Feb 12, 2015 03:33 AM
wotan
17
Nov 5, 2013 09:08 PM
remhaust
Jul 2, 2011 12:30 AM
Dilliw
May 18, 2004 09:47 PM
