Drop Axle Pivot
Old Jul 21, 2016 | 12:15 PM
greencity's Avatar
greencity
Drop Axle Pivot
First post, Ive been lurking around for a while and got a good bit of information. But I can't find information for Drop Axle Pivot Brackets on the forum. I have a 95 F250 w the 460 that I just purchased and have bought a 2.5in add a leaf pack from Tuff Country because the previous owner added a three inch block lift to the rear and for some reason neglected the front. So I would like to know if I would be able to skip out on new axle pivot brackets for such a small lift because they are coming in at a price more expensive than the actual springs. Thanks ahead of time.
Old Jul 21, 2016 | 12:39 PM
'89F2urd's Avatar
'89F2urd
The right way to do it is always a drop bracket. You never know how much lift you'll get with add a leaf, and add a leaf can be detrimental to ride quality.
Then comes alignment, the camber adjustments can only go so far, if you add leaves to the front and you end up outside the camber adjustment range, you'll be buying drop brackets anyway.
Old Jul 21, 2016 | 12:41 PM
xrsfsho's Avatar
xrsfsho
I'm not 100% sure but if you use that you might want to get camber shims. you might not be able to stay in spec while lifting the front. then afterwards you will need to get an alignment (which you should do after the lift settles anyways)
Old Jul 21, 2016 | 01:17 PM
greencity's Avatar
greencity
Thanks guys,
Ill probably just install the leafs and see if I can get a proper alignment, if not the brackets it is.
Old Jul 21, 2016 | 01:20 PM
'89F2urd's Avatar
'89F2urd
Keep in mind, you will need springs to match the drop bracket...so you may end up spending money twice.
Old Jul 21, 2016 | 01:30 PM
greencity's Avatar
greencity
I would need a coil spring on the leaf spring system? I didn't realize how big of a can of worms I was opening buying this add a leaf
Old Jul 21, 2016 | 01:35 PM
'89F2urd's Avatar
'89F2urd
No, nothing to do with coils:
The drop bracket is designed to match a certain amount of spring lift to maintain proper geometry. My point was, if you add a leaf and you can't align the truck, you will end up buying a lift kit with springs that match the drop brackets.
Old Jul 21, 2016 | 01:54 PM
greencity's Avatar
greencity
Got it, im going to hope it just works and move from there.
Old Jul 22, 2016 | 08:37 AM
Briansshop's Avatar
Briansshop
I think the bushings will cover a 2.5" lift. The only way to know is to try it like you're saying and see.
The opposite direction, my F150 has 3" drop beams/3" drop springs and I was able to get the camber in spec.
HaydukeLives
Offroad & 4x4
Sep 7, 2021 09:00 PM
william16339
Oct 25, 2016 08:57 PM
Ben24
May 21, 2014 11:46 AM
John 300
Oct 9, 2010 04:51 AM
460_Maniac
Jun 28, 2006 09:50 AM
