Installing 4R70W
Old Aug 18, 2003 | 06:03 PM
CT's Avatar
CT
Question Installing 4R70W
Advice please. Installing a used 4R70W in my 1995 F-150 4x4 with a 302 V-8. Replacing the same that was in there, but have never installed one myself. The truck has been sitting without a transmission for awhile, bare from the flexplate to the rear axle. Is it the best way to start by bolting the torque converter to the flywheel, then sliding the trans up to it? The converter is mostly empty, should it be filled with fluid before I put it on, and how much? I have no transmission jack, so will be trying to get it in by using a cherry picker chained to the transmission through the doghouse cover. Any insights by those more experienced into problems I might encounter would be appreciated. I really don't want to miss a step or do something that would goof up the end result.
markcass123
Jun 3, 2013 04:15 PM
sewellky30
1997 - 2003 F150
May 9, 2007 02:39 AM
eviljarv
Oct 6, 2006 06:42 PM
jwatsjold
1997 - 2003 F150
Nov 27, 2004 11:08 AM
