Transmission replacement questions
Old Jun 2, 2013 | 08:35 PM
markcass123's Avatar
markcass123
Hey,
I have a 2001 e350 with a 5.4 and a 4R70W transmission. The transmission recently went and I am looking for a used replacement. Can I take a 4R70W from any vehicle and it will be a direct swap? More praticularly I found a reasonably priced 4R70W from an e150. Will this work in my e350? I am assuming it would but I really dont want to order this thing and have it get here and have a 250 lb paper weight !
Thanks and any information is useful !
-Mark
Old Jun 2, 2013 | 08:36 PM
markcass123
also the used transmission that i am looking at is from a 1999 150 and my van is from 01-02
Old Jun 3, 2013 | 01:08 AM
joshofalltrades's Avatar
joshofalltrades
it should fit. i just looked it up on oreillyauto.com, transmission for a 99 e150, and it appears to fit things from about 96-05, ranging in size from a mustang to an e450. on that list was your e350
Old Jun 3, 2013 | 04:15 PM
95e150CW's Avatar
95e150CW
Your donor choices are a 2001-2003 E250/E350 with the 5.4L. The other transmissions will not swap. 5.4L backing transmissions have a different cut of gear in them than the 4.2L/4.6L transmissions, to help them cope with the torque output. AFAIK the van transmissions use a different pan to clear the y-pipe.
carrfamilynj
Jan 12, 2018 08:34 PM
Calvin Thomas
Nov 19, 2016 08:18 PM
signut
Sep 12, 2014 11:23 PM
plumber01
1997 - 2003 F150
Apr 16, 2010 05:13 PM
blyster
Modular V8 (4.6L, 5.4L)
May 9, 2001 05:59 AM
