Code 172
Old Aug 18, 2003 | 05:07 PM
markus's Avatar
markus
Code 172
I have a 95 F150 5.0 4x4 with about 130,000 miles. Over the past month or so I have been sporadically get a Check Engine light to come on when I'm on the highway usually after driving over a large hill or accelerating to pass but not limited to those situations. Also my truck doesn't appear to run any differently when the light is on.
I pulled codes KOEO passed (111) as did KOER (111) but I have 172 in memory and that's the only code in memory. I started basic. I looked over the exhaust manifolds and y pipe for cracks and I didn't see any. I also looked over all the vacuum tubes and didn't see any leaks there either. I've been using the clean your fuel injectors additive for the past tankful of gas with no results as well. My next step is to check/replace the fuel filter. Is there a way I can test the O2 sensor? What else should I try? My truck is a little on the sluggish side could I need my injectors cleaned or replaced? Thanks.
Old Aug 19, 2003 | 07:28 AM
fishin1976's Avatar
fishin1976
Code 172
Anybody know what a code 172 is? I don't have my book in front of me.
Old Aug 19, 2003 | 07:37 AM
djd67's Avatar
djd67
Code 172
172 in my book says hego or ho2s oxegen sensor
Old Aug 19, 2003 | 07:40 AM
djd67's Avatar
djd67
Code 172
for more info refer to your haynes man. 4-22(15)
Old Aug 19, 2003 | 08:09 AM
markus's Avatar
markus
Code 172
Oh yeah I forgot Code 172 is O2 Sensor reporting a lean condition.
Old Aug 24, 2003 | 06:25 AM
markus's Avatar
markus
Code 172
I changed the fuel filter yesterday and I still get the Check Engine light to come on while on the highway . Should I have reset my computer during the filter change? BTW the filter was noticablely harder to blow through than the new one but none of the gas that poured out of it was discolored or murky . What should my next step be? Professional Injector Cleaning? I'm still looking for an 02 Sensor test.
Old Aug 24, 2003 | 06:04 PM
steve83's Avatar
steve83
Code 172
The Haynes manual tells how to test the HEGO with a multimeter, but check your engine bay for a vacuum leak. Then test the fuel pressure with a gauge on the fuel rail.
Old Aug 27, 2003 | 06:21 PM
markus's Avatar
markus
Code 172
steve83 - Fuel pressure was 30psi at idle. I had my brother (a second set of eyes) look over the vacuum lines and he couldn't find a leak either. Thanks.
