92 Explorer Shifting Problem
Old Aug 18, 2003 | 04:45 PM
dgalloway's Avatar
dgalloway
Question 92 Explorer Shifting Problem
Have a 92 Explorer XLT and it shifts fine until it is time to get into overdrive. It does not even try. Could This be a vacum Problem? I would appriciate any help I can get. Thanks
Old Aug 18, 2003 | 05:41 PM
mrshorty's Avatar
mrshorty
The 3-4 shift is electronically controlled. Start by checking the 3-4 control circuit. If that checks out, then check to see if the PCM is telling the transmission to shift. If it isn't, then there is a problem with the engine management system (maybe bad data from the TPS or VSS). If it is, then there could be a problem inside the transmission (bad OD solenoid, or worse).
maverick_43
Engine Swaps
Nov 21, 2025 01:20 PM
'92FlareSide
Apr 20, 2015 08:16 PM
insideout414
13
Mar 6, 2010 05:56 PM
njtinman2
Oct 8, 2006 09:40 PM
Burnsy
Nov 22, 2005 06:47 PM
