So many questions....
Old Jul 18, 2016 | 12:47 PM
jakeharp's Avatar
jakeharp
Question So many questions....
1976 F250 390/c6 4x4- Standard specs - No hotrod planned ..Rebuild only has 7k on engine, but sat for years, so every seal is leaking.
When I took off valve covers, the valve train looked great, no sludge or mucky mess (thank god, cuz I was holding my breath) was clean and orderly.
Im starting to order parts, I have some quick questions, that seemed simple but what the heck
Thermostat temp selection, looks like 205F was the stock, what do you guys recommend ? Go lower ?
Pushrods ? should I replace them even if they look good? I already have the valve stem seals to replace the old ones.
Head bolts, intake manifold bolts, rocker bolts ? Replace them all ?
Should anti seize go on them all ?
Engine Block heater ? Im leaning towards a lower hose in-line style vs. the freeze block plug style, just because the potential leak and access issues.... what say you ?
Old Jul 19, 2016 | 10:57 PM
jakeharp's Avatar
jakeharp
Talking Anybody ?
Anyone wanna chime in ?
Old Jul 19, 2016 | 11:01 PM
351Cleveland C4's Avatar
351Cleveland C4
180-195
Reuse pushrods and bolts
Anti seize is a no, except on water pump bolts.
Freeze plug style is much more effective. Hose style won't do anything for you.
Old Jul 19, 2016 | 11:25 PM
HIO Silver's Avatar
HIO Silver
Originally Posted by 351Cleveland C4
180-195
Concur.
But apply Teflon sealant paste on bolts that penetrate into a water jacket... IIRC, the two bolts securing the thermostat housing.
Old Jul 20, 2016 | 09:21 AM
jakeharp's Avatar
jakeharp
Thanks
Thanks fellas, got my cherry pick'er together last night, after a complete shipping debacle that has set me back a week... So this weekend the jewel will come out one way or the other or piece by freakin piece if necessary
Old Jul 20, 2016 | 01:02 PM
4x4slik's Avatar
4x4slik
Antiseize is a must on the exhaust manifold bolts.
Old Jul 20, 2016 | 02:55 PM
HIO Silver's Avatar
HIO Silver
2x.. ...Or convert to studs.
I was fortunate enough that the POs of my 70 and 73 used anti-seize. On my 71 F250, I picked it up from the original owner and he wasn't much of a wrench. I'll keep my fingers crossed but be well prepared.
Old Jul 20, 2016 | 03:01 PM
351Cleveland C4
On all the engines I've worked on, I've never had much trouble with manifold bolts. But rather the two connector studs on the pipe end. Those always seem to be stuck and rusted badly.
Old Jul 20, 2016 | 04:47 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by jakeharp
1976 F250 390 /C6 4x4- Standard
1968/76 F100/250 4WD: The only V8 available: 360 2V
On sale day, 360's magically become 390's!
Measure the stroke to determine engine size: 360: 3.50" / 390 = 3.78."
Old Jul 20, 2016 | 11:32 PM
jakeharp's Avatar
jakeharp
Thumbs up yes'er
I was worried about the 360 turned 390 also..... I have the receipts from the shop that rebuilt it in 2001 with all the 390 specs and they documented the receipt as a 76' 390....
Old Jul 21, 2016 | 12:05 AM
Tedster9's Avatar
Tedster9
Your profile says you live in Nevada... I don't think you should need a block heater? But they are standard issue for places like North Dakota, Montana and Edmonton, interior Alaska etc
Old Jul 21, 2016 | 09:19 AM
jakeharp's Avatar
jakeharp
Nevada
I live in Northern Nevada, trust me, its the unknown, unspoken, no-body cares about part of Nevada that I love, and it gets COLD in the winter, single digits and sub-zero are common from January to March..... Most folks hear Nevada and think Vegas or Reno..... Take a looksy at the the historical temps for Ely and Elko Nevada.... We have had coldest spot in the nation once or twice thru the years
Old Jul 21, 2016 | 11:07 AM
Tedster9's Avatar
Tedster9
Well... OK.
Had one of the block heaters that installs inline with the lower radiator hose. Seemed to work OK to me, but never really put it to the test. A garage is a beautiful thing.
Jason Neuman
Sep 22, 2014 03:15 PM
1993460F250
Mar 30, 2014 09:06 PM
Wieckster
Sep 26, 2008 08:33 PM
tgowers
Jan 10, 2006 11:39 AM
