Ford In-Vehicle Tech Discussion area for Ford Sync, Sync AppLink, MyFord Touch, Ford Supplied SiriusXM Radio, Ford Work Solutions, etc.
Sirius Weather Map issue
Old Jul 17, 2016 | 08:54 PM
tmont's Avatar
tmont
Have a 2016 SD 250, and am having an issue with the Weather Map. If you magnify the screen, the map stays clear but any weather issue (for example a thunder storm) does not display clearly in the magnified version....it appears blurry. I see where another owner had this issue in a 2014 post, but did not see a resolution. Anyone else had this issue and found a solution? Thanks in advance. Tom
Old Jul 18, 2016 | 09:44 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Both my 2013 (Sync 2) and my 2016 Taurus (Sync 3) Nav systems do the same thing.
Problem is, I believe, Sirius doesn't provide a high-enough resolution image for it to look decent when you zoom in. That smudgy looking image is the best that you can hope for.
Old Jul 18, 2016 | 09:54 AM
tmont's Avatar
tmont
Thanks for replying. I was wondering if that was the case. Tom
rbsev
Jun 5, 2017 04:26 PM
DIYMechanic
398
Aug 30, 2014 07:24 PM
almightywad
Jul 22, 2014 02:41 PM
LACityFD
2004 - 2008 F150
Dec 30, 2010 08:13 PM
