Engine launched oil dipstick
Old 07-16-2016, 06:57 PM
Brian Young II's Avatar
Brian Young II
Brian Young II is offline
Ok, lately this engine has been giving me issues. People suggested that it could be blowby. I replaced the valve cover gasket which was causing some of the smoke. Today the first test run. It did great in the parking lot. Got on the road and really put the engine on a load.it sounded good, I was feeling proud that I might have finally fixed it. A quarter mile down and I hear a small bang. Pulled over and it was the dipstick. I still had great oil pressure and sufficient amount of oil. On the way back. I can hear hissing like air was leaking. I haven't been able to determine the source. I haven't had the time to put the old air filter on with the oil cap connected to it. Maybe it was my on eagerness that got me. Inline 6 300
Old 07-16-2016, 09:35 PM
co425's Avatar
co425
co425 is offline
Sounds like lots of blow by or a stuck pcv valve.
Old 07-16-2016, 10:32 PM
Brian Young II
Last I checked the pcv valve was still good. Probably the blow by. Is it a leak down test I need to do?
Old 07-17-2016, 07:35 AM
hasteranger's Avatar
hasteranger
hasteranger is offline
I'd start with a compression test. If low add a cup of oil per cylinder and see if it rises.
Old 07-17-2016, 08:05 AM
460me's Avatar
460me
460me is offline
My 460 was blowing oil out the dip stick,one cyl was low.When I took it a part I had a broken piston ring.
Old 07-17-2016, 09:48 AM
78 PEB's Avatar
78 PEB
78 PEB is offline
Don't put a CUP of oil in each cylinder..........You will hydro lock the motor.........maybe a couple of teaspoons full at the most.
Old 07-17-2016, 09:58 AM
Brian Young II
Ok so say it's the ring(s) which I think it is. The bad rings also causes the hissing or could that be a whole new problem?
Martialpax
18
09-12-2019 08:02 AM
82fordowner
06-13-2016 12:00 PM
BarryLM
06-18-2013 08:40 PM
jimi
08-07-2007 09:50 AM
showtime946
09-09-2003 01:29 PM
Quick Reply: Engine launched oil dipstick
