Sponsored by: Real Truck
headlights on with switch turned off
Old Apr 26, 2005 | 01:10 PM
madriding1's Avatar
madriding1
I have a weird problem. My highbeam indicator stays lit as well as the headlights when the switch is in the off position. Also noticed some clicking noises from a black "relay type" box located under the dash in the middle. Truck is a 2000 f250 SD. Anyone ever experience this? Thanks
Old Apr 26, 2005 | 03:06 PM
FordRuss's Avatar
FordRuss
I'll at least get this bumped back up..
Welcome to FTE... Sounds like you just have a faulty headlight relay.. The contacts are probably stuck.. You can pull it & the headlights should go off.. You can try smacking it gently & see if that frees the contacts, but I'd grab a replacement one from your local auto parts store..
Good Luck,
Russ
