Fuel pump video
Old Jul 16, 2016 | 12:24 PM
therigwelder's Avatar
therigwelder
Fuel pump video
I know this can't be right and must be the root of my problems. The bowl won't fill up and I got no pressure coming out the FPR.this fuel pump has less than 6 months use.I put six gallons of diesel into the front tank to be sure it had fuel.I have been working on this truck whenever I have a free moment for 7 months. I want and need this truck to run this weekend."God willing and the creek don't rise" I sure hope I posted the link right and y'all can give me some help
PS if the video is to dark tell me and I will shoot another with lighting
Old Jul 16, 2016 | 01:31 PM
knottyrope's Avatar
knottyrope
That don't look good at all. Remove the hose on the right and connect a long hose to reach a container of diesel and see if it pumps better. If it don't then pump is bad. If it does then you have tank or fuel selector valve issue.
Old Jul 16, 2016 | 01:50 PM
therigwelder
I replaced the airtex fuel pump with a known good carter fuel pump and I didn't get any fuel pumping out this time.I will try the long hose and diesel and see if it will pump. I just noticed my fuel gauge is pegged way past full no matter what tank it is on
Old Jul 16, 2016 | 04:24 PM
IDMooseMan's Avatar
IDMooseMan
I agree.
Since these are mechanical pumps, I need to ask if the shaft possibly fell out, is misaligned, or possibly sticking, and causing the issue.
Old Jul 16, 2016 | 05:39 PM
therigwelder
Switched to the rear tank,it filled the bowl ups lot quicker than the front tank.obviously there is a problem with the selector. The bowl is full and I am occasionally getting wisps of white smoke from the exhaust pipe but still no start
Old Jul 18, 2016 | 04:31 AM
therigwelder
Still not getting pressure at the FPR.I took it completely off the bowl,took it apart and cleaned everything.any ideas?
Old Jul 18, 2016 | 07:24 AM
knottyrope's Avatar
knottyrope
did you try pumping from a JUG with a hose connected?
need to rule things out before assuming
Old Jul 22, 2016 | 05:55 AM
79jasper's Avatar
79jasper
Originally Posted by IDMooseMan
I agree.
That's where I would start. If someone didn't know what they were doing, it'd be real easy to not notice the tappet missing.
Or your lines have something stuck in them. Blow them out from the engine side with compressed air.
Old Jul 22, 2016 | 07:58 AM
knottyrope's Avatar
knottyrope
with no tappet there will be no pumping at all
when I replaced mine the tappet would fall out the old one and no way with out will it pump
onefarmer
May 11, 2018 11:05 AM
86ford302help
Oct 4, 2013 09:03 PM
merccougar93
Large Truck
Nov 5, 2011 03:55 PM
myutesux
Feb 15, 2010 10:38 PM
Fire Rooster
Jan 12, 2009 08:17 AM
