Donor truck help
Old Jul 15, 2016 | 10:43 PM
Pruitt66's Avatar
Pruitt66
Donor truck help
I have a 66 f100 and have found a 85 f150 am curious if anyone knows if the disc brakes from it can be bolted on to mine the same as the 73-79 trucks can. Any help would be appreciated.
Old Jul 16, 2016 | 09:23 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Pruitt66
I have a 66 f100 and have found a 85 F150, am curious if anyone knows if the disc brakes from it can be bolted on to mine the same as the 73-79 trucks can.
1980 and later is not the same!
You need the disc brakes from: 1973/79 F100 2WD & 1975/79 F150 2WD
Old Jul 16, 2016 | 07:39 PM
Pruitt66's Avatar
Pruitt66
Thanks that's what I thought. What about a body swap on to the 85? Would that be a feasible idea or too much modifying?
Old Jul 16, 2016 | 07:43 PM
jowilker's Avatar
jowilker
You can probably make it happen but it will not be a bolt on.
John
racer2012
Dec 9, 2021 11:32 PM
Gouge Eye
Jul 12, 2012 11:13 PM
jloktalGst
18
Apr 15, 2012 11:37 PM
f63
Oct 30, 2009 04:34 PM
Trevor Rush
Jul 4, 1999 12:19 PM
