1948 F-6 shifter question
I'm not sure I understand. "so it releases"?
I pulled the clutch recently to replace the fork since it was bent.
I was able to see the clutch work when I had the shifter back in incorrectly.
I was able to depress it and it stopped the main drive shaft.
Now I've put the shifter back in with what I think is correct, I have neutral back.
Is there a procedure in shifting this F-6? It has a high and low.
Thanx.
Thanx.
That's what I love about this forum! Great advice, people. I went back and adjusted the clutch 1/8+ inch, moving the clutch pedal free movement and arm and the truck moves into gear perfectly! I moved her up a few feet in second gear, then found reverse and moved it back.
My wife is on a business trip and told me that if I move her (the truck) before she gets back and can see (this is a year in the making), I'm dead... So now I'll pretend on Weds that it was the first time...
Possibly this week upon my wifes return. The brakes are still if'y. The master cylinder is leaking. I have a solid parking brake though. If I take the truck out it will be in the neighborhood first to access the brakes. It's nice and flat.
- that the brakes are dragging (sitting 2 years)
- I can't seem to get it into HIGH (lo/hi switch) so it sounds like it is winding
- the rear end is having difficulty.
I'm not sure right now though. Any insight is much appreciated. Thanx.
#28
#29
The shifting of the two-speed axle requires a fair amount of vacuum for several seconds (assuming it's a vacuum shift with a **** on the dash). You want to make sure that all your vacuum connections are good and tight. There should be a placard on the dash with instructions.
Hey, great videos, and keep up the good work.
webstar61
10-31-2012 08:15 PM
S.N.A.F.U
08-25-2005 04:50 PM
1996F150kid
09-26-2003 05:17 PM
