Honing Help
Old Jul 14, 2016 | 08:41 AM
72CC428's Avatar
72CC428
Honing Help
Okay guys I got the three stone honer. Never used one before. I used a Dingle berry honer back in HS. I watched a few videos on honing and I gave up since every one of them described doing it differently.
The machinist that helped me w/ piston and ring info told me to use ATF and the videos were all over the board with one guy going dry, to another guy using WD40.
One guy said to hone until the surface is uniform shiny. Another guy honed
the bores for like 3 minutes each with his drill on high speed?
So again, I ask for sage advice from the Seers at FTE. What do you guys say?
Old Jul 14, 2016 | 09:01 AM
MIKES 68 F100's Avatar
MIKES 68 F100
drill on High speed is a no no , you will destroy the honer ( I did)
I used Wd40 , I did mine for probably 3 minutes , but I think this is different for every engine . Just do as much honing as needed to get it even . I am sure others will chime in .
**Tip don't lift or lower the hone out of the cylinder more than like a 1/2 inch with it spinning .
Old Jul 14, 2016 | 05:07 PM
JEFFFAFA's Avatar
JEFFFAFA
I quote myself from one of your other threads.
Is there a ridge in the cylinder bores at the very top? If so then you need it bored and oversize pistons and rings. If not then do at least a hone job to remove the rust in your cylinders.
<a href="https://tse3.mm.bing.net/th?id=OIP.Mf4beb4a26696b64105f8617e50805579H0&pid= 15.1&P=0&w=300&h=300" target="_blank">
If you buy this tool also, put your drill on a medium speed. Oil the cylinders down with a thin layer of engine oil. Set the diameter of the hone's stones so they aren't too tight in the bores. While spinning the hone in the bores with the drill move it up and down medium fast. You want to only remove the rust, get the full cylinder top to bottom, and put a criss cross pattern in the bore.
72CC428
31
Aug 11, 2016 01:37 PM
FordPickupMan351w
General Automotive Discussion
Jan 9, 2008 04:24 PM
Chumbucket
Apr 19, 2006 09:20 PM
blu
Aug 22, 2004 12:26 PM
ddime2000
Jul 14, 2001 07:38 PM
