Ford aod shifter
Old Jul 12, 2016 | 10:36 PM
Houser16's Avatar
Houser16
Ford aod shifter
I put a Ford aod into my 1960 f100 and I am trying to find a shifter for it that I can use the factory shift linkage on the side of the transmission i don't want to have to change it. It just has the little ball that linkage would snap onto. Thanks
Old Jul 12, 2016 | 11:06 PM
85e150's Avatar
85e150
Column or floor shifter? Did you hook up and adjust the throttle valve link or cable?
Old Jul 12, 2016 | 11:21 PM
Houser16's Avatar
Houser16
Floor and yes I hooked up the TV cable
This is what the linkage looks like
Old Jul 12, 2016 | 11:33 PM
85e150's Avatar
85e150
Would a Mustang shifter work? You are probably right on top of the trans vs. the Mustang shifter maybe sitting further aft.
I'm drawing a blank on what other models using the AOD would have had a floor shifter. T bird maybe. I think it was installed in some pickups, but with a column shifter.
Old Jul 12, 2016 | 11:41 PM
Houser16's Avatar
Houser16
Yea a mustang shifter would work but I can't even find one if those that would work
Old Jul 13, 2016 | 10:05 PM
85e150's Avatar
85e150
Do you mean the Mustang shifter won't attach to your trans?
What was the trans out of?
gogoat
Oct 25, 2015 07:45 PM
Jeff and Nicolle
15
Dec 13, 2010 05:37 PM
53Trucker
Dec 15, 2005 06:58 AM
tip49
Dec 14, 2005 08:50 PM
