AOD Shifter
Old Oct 22, 2015 | 08:53 PM
gogoat's Avatar
gogoat
AOD Shifter
I need to find a OAD shifter for my 49 F1. Any ideas?
Old Oct 22, 2015 | 09:00 PM
CharlieLed's Avatar
CharlieLed
Most Mustangs had a nice floor shifter with cable for the AOD
Old Oct 25, 2015 | 09:28 AM
tip49's Avatar
tip49
Aftermarket
I went with the Lokar classic which I'm very happy with. Did consider Mustang shifter but orientation of it changed my mind
Tom
Old Oct 25, 2015 | 10:20 AM
jonf's Avatar
jonf
My F-1 had 3 on the tree so I used that to shift the AOD.
Old Oct 25, 2015 | 06:58 PM
yamagrant's Avatar
yamagrant
I'm using the Lokar nostalgia:
Old Oct 25, 2015 | 07:08 PM
builttodrive's Avatar
builttodrive
I have installed a few of the lokars in trucks I have restored and they work well. You can use pretty much any aftermarket 3 speed auto shifter as long as you install the B&M shift shaft lever. I have used the B&M hammer in my mustang and was not a fan. The Hurst VMatic that I have in it now is MUCH BETTER!
Old Oct 25, 2015 | 07:45 PM
Flat Ernie's Avatar
Flat Ernie
Exactly what I did in my '54 F100...I used the "lower" gate (2-3) and set it up to work correctly. I had to fabricate an arm on the trans, but it was pretty straight forward.
Did the same on my '51 F1 Panel years ago, but with a C6.
Houser16
Engine Swaps
Jul 13, 2016 10:05 PM
TJ62
Nov 29, 2014 11:23 PM
tip49
Dec 14, 2005 08:50 PM
