Extended Sway bar links? RSK?
07-12-2016, 05:33 PM
on
I recently installed a PMF RSK on my 2 x 1997's. The sway bar end links seem way to short now. The lifts are both 6".. Looks like I will be needing sway bar end links of a longer variety? Any suggestions? Thanks fellas..
07-12-2016, 10:49 PM
Mine are short too but only have a 3 in lift but they function. Rough country has a 4 inch extended one for 35 bucks that I was thanking of getting.
07-13-2016, 05:58 PM
on
Quote:
Originally Posted by
knottyrope
I'll check into those. I wonder about just building my own? Anybody ever do that? Or, lengthening the originals?
07-14-2016, 06:10 AM
Royson12
If you have a welder. Cut them in half and insert 1.5 in into a 9 in pipe length and weld pipe to them halves.
07-14-2016, 09:39 AM
on
knottyrope
Im thinkin on doin that.
07-16-2016, 02:49 PM
if you are using stock SuperDuty springs and a 3" or less RSk....
use STOCK REAR sway bar end links from 80-97 f350.
07-20-2016, 07:47 AM
on
Diesel_Brad
I think my lift is a 5"
07-21-2016, 05:51 AM
Royson12
I guess you did not install the RSK and are running 37s
07-22-2016, 04:24 PM
I cut mine, layed them into two pieces of small angle from home depot, and welded them.
07-22-2016, 05:11 PM
on
Diesel_Brad
No, it is a rsk kit from PMF. I installed x code super duty spings with it. If i remember right, the guy at PMF told me it would equal about a 5" lift. I might me wrong on the exact height of lift. But its tall.
07-22-2016, 05:12 PM
on
It does have 37" militarys on it also.
07-22-2016, 05:16 PM
on
This is the beast in question.
07-23-2016, 06:49 AM
Ok, then NO. The stock rear links will not work.
I would look at some 6" lift ones, or get yourself some thick wall tubing so you can cut and extend your stock ones
07-23-2016, 10:30 PM
on
Mine are from skyjacker... I think they're $100?
Shedd
2017+ Super Duty
07-22-2019 01:32 PM
bmlawson
02-03-2009 03:04 AM
quietman
1999 to 2016 Super Duty
03-14-2005 06:02 PM
ttb29
10-22-2004 02:44 PM
