Extended Sway bar links? RSK?
I recently installed a PMF RSK on my 2 x 1997's. The sway bar end links seem way to short now. The lifts are both 6".. Looks like I will be needing sway bar end links of a longer variety? Any suggestions? Thanks fellas..
Mine are short too but only have a 3 in lift but they function. Rough country has a 4 inch extended one for 35 bucks that I was thanking of getting.
Originally Posted by knottyrope
(Post 16419703)
Originally Posted by Royson12
(Post 16421359)
I'll check into those. I wonder about just building my own? Anybody ever do that? Or, lengthening the originals?
(Post 16422313)
If you have a welder. Cut them in half and insert 1.5 in into a 9 in pipe length and weld pipe to them halves.
if you are using stock SuperDuty springs and a 3" or less RSk....
use STOCK REAR sway bar end links from 80-97 f350. |
Originally Posted by Diesel_Brad
(Post 16427822)
(Post 16437559)
I think my lift is a 5"
I cut mine, layed them into two pieces of small angle from home depot, and welded them.
https://cimg4.ibsrv.net/gimg/www.for...d205cc4852.jpg |
(Post 16439993)
I guess you did not install the RSK and are running 37s
It does have 37" militarys on it also.
This is the beast in question.
https://cimg4.ibsrv.net/gimg/www.for...9871b8accf.jpg |
Ok, then NO. The stock rear links will not work.
I would look at some 6" lift ones, or get yourself some thick wall tubing so you can cut and extend your stock ones |
Mine are from skyjacker... I think they're $100?
